A/C Troubles
Old May 6, 2012 | 01:43 AM
clbychil's Avatar
clbychil is on a distinguished road
Default A/C Troubles
About a year ago I had nearly all of my A/C components replaced(compressor, accumulator, hoses, orifice tube, etc), it cooled fine through the summer then quit sometime in the winter. I figured there was a leak so I gave it a charge up and it cooled fine for about 3 weeks. Now its not cooling and I checked to see if it was a leak again but the pressure is right where it should be. Compressor kicks on fine and the pressure hovers about where it should but it doesnt cool at all. Any suggestions as to what the problem may be and what I can do about it? Thanks
Old May 6, 2012 | 03:04 PM
4x4blazerguy's Avatar
What are your High & Low pressures? Are you sure your not over charged? R134A if over charged won't cool. Is your condenser dirty or plugged up?
Old May 6, 2012 | 03:43 PM
98blazin's Avatar
98blazin is on a distinguished road
blend door ?
Old May 6, 2012 | 03:48 PM
pettyfog's Avatar
Let's look at the basics. Does the accumulator get cold? Does the AC clutch cycle at all?
Old May 6, 2012 | 04:13 PM
clbychil's Avatar
The accumulator does not get cold, but the AC clutch does cycle.
Old May 6, 2012 | 04:25 PM
pettyfog's Avatar
How long does the clutch stay engaged?. If under three seconds, Remove the connector at the ACCUM cycle sw and sjump those sockets.
Does the Accum get cold, then?
If you are using the gauge that comes with can, they are crap.. what do you expect for costing about a buck to make.. and cant be trusted.
Not saying that's the problem but You cant give us numbers in PSI as to when clutch engages and disengages can you?
Old May 6, 2012 | 07:06 PM
clbychil's Avatar
Yes, it is engaged for under three seconds. Engages at 55 psi and quits at 15.
Old May 6, 2012 | 08:40 PM
clbychil's Avatar
and yes the accumulator does cool slightly while the connector is jumped. Slightly as in the air coming out is no longer warm but still not Very cool or cold.
Old May 6, 2012 | 09:24 PM
With out Hi & Low pressure readings every one is just guessing.
Kellogg
Jan 31, 2010 04:28 PM
jaybird33081
Jan 4, 2010 11:19 PM
baja457
Oct 28, 2007 08:21 AM
getonerd
Sep 28, 2007 07:20 PM
2blzers
May 13, 2007 09:09 PM
