Caliper Bolts
Old Aug 8, 2013 | 03:33 PM
dobyken's Avatar
dobyken is on a distinguished road
Default Caliper Bolts
Does someone know the proper size for the front caliper mounting bolts for a 1999 4WD? The auto stores don't seem to have them..only the slide bolts. I thought they were M12-1.75 x 40mm but the thread diameter was just a tad small and wouldn't tighten. The 1/2-13 screws in but is looser than the M12.
Old Aug 8, 2013 | 04:30 PM
newguy's Avatar
Bring one of the old bolts to hardware store and match it up
Old Aug 8, 2013 | 05:29 PM
dobyken's Avatar
Why didn't I think of that? Oh...I don't have the old ones. I could, however, pull one from the other side but if someone knows the size it would save me a little time. I did run my taps through the bracket and it looked like M12 was correct but just a tad small.
Old Aug 8, 2013 | 10:05 PM
spittybays
Guest
Posts: n/a
Dealer parts dpt. guy might know if you can get one over forty.
Old Aug 9, 2013 | 07:27 AM
dobyken's Avatar
I just got done pulling out the slide bolts and I'll bring the mounting bracket to the hardware store....beats pulling off one of the bolts from the other side of the car which is about 6" from the garage wall so I would have to put the bad side back together and move the car to the other side. For future reference I'll list the bolt size which might save someone else some trouble. I spent over 2 hours searching and the best I could find is that it takes a 18mm socket which most everyone knows already.
Edit: The bolt that mounts the 4wd front double piston caliper is a M14-2.0 x 40mm. Although it's the correct thread the socket required is larger than 18mm. A 7/8" box wrench was a near perfect fit so it would be somewhere around a 22mm socket if I had one.
Old Aug 10, 2013 | 01:53 PM
step66's Avatar
That parts store must not have been worth **** as these are normal stocking items at all parts stores as these fit MANY GM vehicles! Sold in pairs for retail $12 or wholesale @ $7...
Ted
Sep 14, 2009 11:26 PM
pigmak
Nov 4, 2007 07:21 PM
classic_cruiser
Nov 2, 2007 08:07 AM
lemon blazer
Aug 7, 2007 08:31 AM
Canadian88
Jul 20, 2006 08:41 PM
