Camshaft sensor question?
Old Feb 23, 2011 | 09:10 PM
blaze21's Avatar
blaze21 is on a distinguished road
Default Camshaft sensor question?
I will be changing my CMP this weekend and I'm wondering about a couple of things. I found a post on CMP replacement and SwartLKK says to line up one the gates on the reluctor wheel with the boss on the sensor. How exactly do you do this? Do I have to turn the engine or something? I see how it can come out once I have the wheel in the right spot but I just don't know how to get it there. Also, am I going to have to go to the dealer to have a relearn or will the computer work it out? Thank you for any help.
Old Feb 23, 2011 | 09:16 PM
blaze21's Avatar
'95 Blazer 'W' 4wd
Old Feb 23, 2011 | 09:20 PM
TouringMike's Avatar
TouringMike is on a distinguished road
Short bursts on the starter until it lines up should do it (that's how I did mine). It takes awhile.
Or
Remove a few spark plugs, get a wrench on the crank shaft by the harmonic balancer, and turn the engine by hand.
Or
Mark the distributor position so you can re-install it in the same position, then pull the distributor out (M10 bolt holds it in). This is the easiest way, but not for people who aren't comfortable with doing this.
Old Feb 23, 2011 | 09:58 PM
blaze21's Avatar
OK, that was what I was thinking but just wanted to be sure. Will I need a dealer relearn or will the computer take care of it? Thanx for the response TMike.
Old Feb 24, 2011 | 06:48 AM
Put the sensor in, and crank away. It's a hall-effect sensor, no programming required.
Old Feb 24, 2011 | 09:44 AM
blaze21's Avatar
Alright alright. Thanks TMike
russ1609
Jan 30, 2012 07:08 PM
fox59
Jul 7, 2011 11:38 AM
rob2129us
Dec 19, 2007 10:03 AM
murfthesurf4
Nov 26, 2007 11:00 AM
88blackzcand95blazer
Jan 26, 2007 04:36 PM
