Can’t find the problem!!
Old Nov 29, 2021 | 12:09 AM
JonPeine's Avatar
JonPeine is on a distinguished road
Thanks so much for the wiring diagram. I’ve looked everywhere for that but couldn’t find it. Can you get it to be any better resolution? I just can’t hardly read it.
Old Nov 29, 2021 | 12:32 AM
GeorgeLG's Avatar
Try this
George
File Type: pdf
Old Nov 29, 2021 | 08:33 AM
GeorgeLG's Avatar
I forgot to mention one other way that modules and sensors can affect each other, reference voltages. Some modules require clean and regulated references voltage and ground as an input to the sensor. These can be 12 or 5 volts dc. Sometimes that reference hi level which comes from the engine computer is supplied in parallel to more than one sensor so if testing reveals a corrupted reference voltage then you must determine the source which is usually either one of the sensors sharing that reference voltage line or the wiring. Same process, you take things offline until the voltage recovers, assuming it’s being supplied by the engine computer properly.
Let me know if you need any help with that class 2 bus analysis.
George
TheSaint
May 22, 2017 09:36 AM
abukinan
Apr 23, 2012 10:24 AM
money pit '00
Dec 26, 2010 04:02 PM
Bradley2424
Nov 22, 2010 10:24 AM
1998LS
Jun 11, 2009 05:22 PM
