Can this possibly be right?
When I first got this Blazer at the end of May, one of the things I noticed was that both front control arm stops were worn down to practically nothing. So I got some replacements and installed them. But now there's hardly any travel before the control arm hits the new stop. See pics. I can feel it bottoming out when driving over only mild bumps. These stops were listed for my vehicle, but they just don't seem right to me. Opinions please.
Slightly higher angle that shows the amount of clearance better.
What I really want to know is ... do these stops (and resulting small clearance) look like what the rest of you have? Pictures would be great.
I don't see which year you have but I would go to Rockauto and look at pics. Unfortunately they don't have measurements but looks like maybe those are for the rear bump stops or different trim package than you have??
Well, I think I've answered my own question, and the answer is "no this is not right!" Seems the stops I installed are actually for a "Z"-something model with so-called "high rider" (or riser) option. I have no idea what that is, but it sure doesn't describe mine. These tall stops are being sold all over the place, even on Amazon, as the standard Blazer replacement. But the better parts outlets, like Summit Racing are showing an ACDelco/Moog part that's completely different and has a rectangular base, instead of the circular one. The thing that threw me off is that the worn-out ones I removed had the circular base. Below is a picture of the non-Z part I ordered. ACDELCO 45G1004 (Moog is same part with different p/n)
Hope this is helpful to someone who made the same mistake I did.
Ah yes. you are referring to the ZR2 option that had larger tires and a raised suspension.
Your experience is a good reminder that just because something is listed as the right psrt, it might not be.
Your thread had me looking up some videos on installation, Based on you needing the same part as I would, I'm wondering if you had to disassemble much to access the stops or could you slip them them in there w/o too much hassle? For your sake I hope it wasn't too much of a PITA.
Also what had you changing them, do they come into use in normal driving or just off-road etc?.
... what had you changing them, do they come into use in normal driving or just off-road etc?.
The rear bump stops are even larger than these ZR2 hi-riders. Much larger. And they're hollow inside. You can see for yourself. You don't even need to jack the truck up. Just crawl under behind the tire with a flashlight.
As mentioned earlier, I changed mine soon after buying the truck in May because, as I was snooping around underneath, I noticed one was worn way down, and the other was missing the filler material altogether. Since those existing stops had the circular base, it appears the former owner made the same mistake I did. Technically, they're not difficult to change, just a stud and a nut, but the nut is in somewhat cramped quarters, so getting your wrench on it takes a little finesse. Recommend using some penetrating oil on the threads and letting it soak for maybe 10 minutes.
Last edited by RedSledge; 09-22-2021 at 08:45 PM. Reason: add detail, correct typo
... Your experience is a good reminder that just because something is listed as the right part, it might not be.
