Can you help me identify rear brake hose?
Old Jul 3, 2013 | 01:30 AM
tooth_dr's Avatar
tooth_dr is on a distinguished road
Default Can you help me identify rear brake hose?
I'm on rockauto looking to order rear brake hoses for my 01 blazer 4.3 4dr LT 4WD.
I've a problem in that my rear calipers were seized when I bought the truck and although I freed them ok, the rear brakes are dragging and the calipers won't release.
Im ordering new calipers as well, but can anyone tell me what hoses I need to order from rockauto to suit my needs? There are outer, lower, centre, I'm not sure which is which. I'm thinking just the ones from the calipers to metal pipes. I'll change all though if needs be.
I'm from Ireland so I want to order all in one go! So far I've ordered so much stuff from the because I cannot get any parts in my country.
Many thanks
Adam
Ps my vehicle inspection is on the 11th July so I need parts a few days before to get all fitted.
Old Jul 3, 2013 | 02:47 AM
Jbsdoom's Avatar
Jbsdoom is on a distinguished road
I am a GM Tech and speaking from past headaches. If you are gonna go as far to replace the rear calipers and outer hoses. You may as well replace the center main flex hose as well as the hard lines going across both sides of the axle. Because I can promise that almost all those fittings are rusted and sized fast. Also be sure to clean out your 2-way splitter on the base of the center line real good with some break clean or parts cleaner. they get gummed up a lot.
Old Jul 3, 2013 | 05:32 AM
tooth_dr's Avatar
Thank you! So two outers and one centre? Some are labelled as lower do I need those?
mdehoogh
Dec 14, 2011 07:49 AM
chuck5104
Apr 3, 2010 08:26 PM
PROJECT85K5
Dec 6, 2009 10:55 PM
pswann
May 10, 2009 01:49 PM
Doran
Apr 14, 2008 09:10 PM
