Candy
Old Oct 23, 2012 | 12:18 PM
cprettymerk's Avatar
cprettymerk is on a distinguished road
Default Candy
Hi! I have a very nice 98 Chevy Blazer from my inlaws.
I have a lot of repairs to do, but right now my problem is that
the fan for the heat/ac is not working. Is this something I can fix?
Also there is a sound in the dashboard-near passenger side that sounded like
a clicking , but now sounds like a buzzing. The sound is not constant, wonder if there is some relation to the fan. Any help or suggestions where to start?
Old Oct 30, 2012 | 12:12 AM
prelude1897's Avatar
prelude1897 is on a distinguished road
sounds like you may need a new heater core or possibly a new relay/fuse.
Old Oct 30, 2012 | 12:23 AM
JohnAfton76's Avatar
JohnAfton76 is on a distinguished road
I do not know if it would be the same, but just after i bought my 85 jimmy, I had almost the same thing going on. I had to put in a whole new fan motor.
Old Oct 30, 2012 | 12:24 AM
50lb_cat's Avatar
The heater core has nothing to do with the fan. Does the fan work on the highest setting but not the lower ones? If so, then its just the blower motor resistor.
If not, I would look into any vaccum leaks or a faulty blend door actuator.
Old Oct 30, 2012 | 08:16 AM
My bad, read too fast and only saw the part saying the heater and ac aren't working.
Old Oct 30, 2012 | 05:54 PM
step66's Avatar
X2 to 50 cat-Its quite clear from symptoms:there is the answer!
Old Oct 31, 2012 | 08:17 PM
Took the Blazer in. The fan for the AC/Heater didn't work at all. 1 of 3 wires was fixed.
The buzzing coming from passenger's side dashboard area is still unsolved. I was told it needed a new fuel pump -that it was making the sound.
Wrong! The fuel pump was replaced and it still buzzes when using turn signal,and recovery and cruise control. Any thoughts on the buzzing? Thanks!
rexazz2
Nov 6, 2013 09:03 PM
gearhead23
Dec 5, 2011 06:42 PM
oktain
May 12, 2010 09:47 PM
Ryanmatt135
Apr 5, 2010 05:22 PM
Colby 04
May 6, 2009 08:04 AM
