Canister Purge Solenoid and Vent Solenoid
Old Jan 19, 2011 | 12:35 PM
Tony H's Avatar
Tony H is an unknown quantity at this point
Default Canister Purge Solenoid and Vent Solenoid
1999 4WD
If I Electrically disconnect both of these, Will I get a check Engine light or not?
I've been chasing a PO442 code and I'm frustrated. I've taken apart the Vent valve and cleaned it. Ran voltage to it and it snaps open and shut nicely. I 've replaced the Gas cap.
And I can't figure why the Purge solenoid by the Intake manifold would be an issue. I'm done playing, Just make it go away
Old Jan 21, 2011 | 07:57 AM
MJay's Avatar
MJay is on a distinguished road
Is it hard starting when cold out? Check your Intake Air Temp sensor. It is the little sensor in the intake elbow tube. It costs about $13 at Auto Zone.
Old Jan 21, 2011 | 09:12 AM
Tony H's Avatar
Starts and runs fine in all temps. Just a Check Engine after Clearing the codes. People point me to these Evap components. Disassembled the one in the rear by the Spare tire. It snaps open and closed nicely, all seems good.
code PO442
Why would a cold start sensor contribute to this Code?
Old Jan 21, 2011 | 10:11 AM
motorcity blazer's Avatar
motorcity blazer is on a distinguished road
Check to make sure all your vacuum lines are in good working order. They run from the transmission up between your rotor cap and firewall. Should be three of them and mine are 7/32 hoses. One runs into the driverside fender above the brake master cylinder. There is a another one that connects to that one that runs into the top of the intake manifold. I had the same code and went through everything you did. Ended up being vac hoses. $1 per foot at autozone.
cmaddox421
Dec 29, 2013 08:33 PM
dj00140
Mar 14, 2011 09:51 PM
Franco
Jan 6, 2011 11:01 AM
Tony H
Feb 23, 2010 08:09 AM
god_zilla00000
14
Jan 5, 2010 05:26 AM
