Cannot remove key sometimes
My 97 started holding the key when I exit the vehicle.
It of course must be in Park and in the off position to remove normally.
I had searched for previous posts and did not really find an answer.
I assume it has something to do with the gear selector since it is intermittent.
Can any one give me the mechanics or adjustments associated with the function, is there an electrical switch involved.
RE: Cannot remove key sometimes
It could possibly be a bad ignition switch, but I think the most likely cause would be the lock cylinder going bad. To replace it safely, you would want to disable the air bag. If it were me, this is one of those things that I would let either the dealer or a locksmith take care of.Using the'search' function for 'key stuck'you cansee what some others have done for this problem.
I had a friend with the some problem and a new ignition lock had 2 b installed.
I just had the same problem with mine. There is a small plug(the size of a nickel)that you can remove with a small flathead screwdriver. Then you can insert that small screwdriver straight up and in which will press on a metal plunger which will manually allow you to remove the key- this will obviously only get you out of a pinch and as the other member said- you will have to replace that ignition part.
this is an old post but o well..
my 97 did this.. some sensor went bad in my coloumn. there is a small hole under a little metal rod.. using a screwdriver push up that rod and key comes right out . i couldnt see spending 140 dollars for it so i zip tied it up all fixed
Seems to be a common issue, My son's 99 has the same problem!!!
I have the same issue with my 97. I have replaced everything ingition ket related in the colum. I noticed if I turned the switch on, pushedthe brake pedal down and mash in the button several times for the shifter release (like you are going to put it into gear), you will hear a click inside the colum and then the key will release. I thought it might be the switch on the shifter itself but the problem is intermittant. Got me stumped.
I'm having this problem with my 99 GMC Envoy. It seems like this has been a recurring GM issue. Wish I could find a solid answer.
ORIGINAL: jburke
Sorry to all that I just saw this thread, but the computernerd is exactly right, In fact I'd be willing to bet that all of you who have posted here have a floor shifter in your truck...... The wiring for the BTSI and the Ignition lock cylinder control actuator (that thing in the column that you push up after removing the plug) is fixed to the shifter assembly, and MOVES every time the shifter is moved! The constant motion bends the wires and eventually they break in two. You can fix it with a simple wiring splice or solder after you remove the console. Niether the ignition switch NOR the ignition cylinder can cause this problem.
