Can't detect leak on a/c system
I purchased a can of freeon that has dye along with the glasses to detect the leak and nothing. i belive the a/c system was empty so is 1 can not enough? once i filled the system with the 1 can the compressor was going on like every 8 seconds and stayed on for about 4 seconds than would turn off and come back on again 8 seconds later and so on... I can't seem to detect a leak. i did notice the a/c blow a lil fresh than what it was, but very slight because it still felt warm. i'm just trying to diagnose the system and fix the leak than take it to a shop so they can fill the system since i've heard that it's best if they fill the a/c with their machine... So is 1 can enough to detect a leak or what's the deal... thanks
I copied this from my All Data Account.
If you are not using a gauge on the low side it will be hard to tell
what is going on with the proper pressures.
Hope this helps.
Capacity Specifications
REFRIGERANT AND OIL CAPACITY
The refrigerant system requires refrigerant and oil in quantities listed:
Refrigerant-134a 0.91 kg (2 lbs.)
Polyalkaline Glycol (PAG) Refrigerant Oil:
HT6 Compressor 240 ml (8 fl. oz.)
V-5 Compressor 265 ml (9 fl. oz.)
CAUTION: Overcharging a system may allow liquid Refrigerant-134a to get into the compressor, causing compressor noise and damage. Undercharging will cause insufficient cooling.
Hope this helps.
I'll give you a spot to check, standing in front of the truck with the hood open look at the A/C compressor, you might find some dye on the back half. Do you have an oil/mess under the compressor on top of the bracket?
sorry to jump in on the topic but my 99 has the dye coming out around the back half of the compressor.is there seals in there to change?i never messed with air conditioning bfore.
i know when i fill this it takes 2 12oz.cans till the guage reads full.
I had added a can of free on with that dye stuff and had found nothing, than i had some free on added about 3 weeks ago and today i come to find out why the a/c wasnt blwoing cold... popped the hood and the lines that connect to the a/c compressor appear to be broken... what could have caused this? I'll probably just end up replacing the a/c, accumilator, in line filter, orphis tube, and condensor. am i missing something or is their one of these that dont need to be replaced? thanks.
BigDaveH
Apr 1, 2014 10:12 PM
Tinted
Nov 20, 2011 06:36 PM
liltittle62
Dec 26, 2010 03:55 PM
wienerdog
Oct 20, 2008 09:56 AM
