Cant seem to find it..does it even exist?
Old Feb 8, 2013 | 09:22 AM
  #21
LannyL81's Avatar
There was an aftermarket alarm installed at some time; the LED in the light control panel and the valet switch in the fuze panel, this could be the problem with the dome lights staying on.
But also check to make sure the instrument panel lite dimmer control is not all the way up which turns on the dome lights and keeps them on, no matter if the doors are closed.
Keep us informed as to what you find.
Old Feb 8, 2013 | 10:35 AM
  #22
Diaita's Avatar
There is a door handle switch inside the door that also turns the interior lights on.
Old Feb 12, 2013 | 09:32 PM
  #23
Maxboost25psi's Avatar
Maxboost25psi is on a distinguished road
Well still no luck with the light issue...however I did do plugs, wires, rotor, distributor cap and other misc things here and there....
Really nice ride for my daughter's first vehicle!
Old Feb 13, 2013 | 07:16 AM
  #24
LannyL81's Avatar
Pull the fuze for the interior lights and check for current drain. Then you can determine which circuit has the current drain....even if it is the one for the interior lights.
Let us know what you find.
Old Feb 13, 2013 | 02:20 PM
  #25
roypai's Avatar
roypai is on a distinguished road
X2 for the door handle switch inside the door - if i forget to unlock my truck and pull the handle the interior lights still come on (to help me find the key?)
nellymerc
Dec 26, 2012 04:37 PM
sledzepplin
May 25, 2010 03:18 PM
mtsumedi
Lifting Tech
13
Oct 28, 2009 09:44 PM
strong blazer
Jun 21, 2008 08:06 PM
