case relearn?
I just changed my distributor. I found my old one was cracked so i bought a good used one and put it in. From what i can see there really is no way of timing like on older engines where u could slightly moved to dist. Is the releran a way of timing the motor any help would be appreciated. my blazer starts right up but is missing bad. THanks Rob
It's hard to answer the question without any vehicle info at all.
Please add vehicle info either in your post or your signature so we have an idea as to year, model, engine etc..
I am sorry it is a 2000 s10 blazer 2dr 4x4 thanks
Hopefully you put the new distributor in exactly in the same position as the old one came out. There is no fine adjustment.
Did you have the plug wires off the cap? If you did then it's possibly that you have a couple in the wrong place, causing an engine missfire.
joey
08-27-2012 06:33 PM
bigkeith11
07-13-2012 10:21 PM
Klturi421
06-10-2012 03:45 PM
GM hater
01-09-2010 02:32 PM
