case relearn
Old May 14, 2016 | 09:09 AM
newguy's Avatar
Default case relearn
Anyone ever do this and does it work?
1. Turn off all of the accessories. With the Air temperature sensor and Coolant temperature within 5 degrees (Centigrade) of each other, start the engine and let it idle in Park or Neutral for two minutes.
2. Accelerate the vehicle to 55 mph at part throttle. Cruise at 55 mph for 8- 10 minutes until the engine reaches operating temperature.
3. Cruise at 55 mph for another 5-6 minutes.
4. Decelerate to 45 mph without using the brakes, and maintain 45 mph for 1 minute.
5. Perform 4 deceleration cycles, without using the brakes, of 25 seconds each where no specific speed is necessary. Returning to 45 mph for 15 seconds in between deceleration cycles.
6. Accelerate to 55 mph and cruise for 2 minutes.
7. Stop the vehicle and idle for 2 minutes with the brake applied and the transmission in Drive (automatic trans.) or Neutral (manual trans.) with the clutch depressed
Old May 14, 2016 | 09:14 PM
newguy's Avatar
Guess not
Old May 14, 2016 | 09:17 PM
That exact procedure was tossed around the GMT360 forums back when I had my Rainier and had a tuned PCM. The method did not work for them and I doubt it would work here as the relearn procedure with a scantool must be commanded to start and a set procedure followed for a new value to be stored.
Old May 14, 2016 | 09:24 PM
Rusty Nuts's Avatar
Are you having a problem with your pcmforless reprogram?
Old May 14, 2016 | 11:08 PM
newguy's Avatar
Have not got it back yet, but read if you use a donor pcm you will need a case relearn.
Old May 15, 2016 | 10:17 AM
You read correctly with regards to a donor PCM. Crankshaft position sensor data is stored in the PCM when the relearn is performed. It remains there until the next relearn overwrites the previous data. If you replace the PCM without performing a relearn, it will use the calibration data from the previous relearn, which is not the correct data for the existing crankshaft position sensor.
Old May 15, 2016 | 12:26 PM
newguy's Avatar
Thanks checking around for a shop at the moment
Old May 15, 2016 | 12:48 PM
Using a capable scan tool, once the year, make, & model is loaded, follow the on-screen safety prompts, (foot on the brake, trans in neutral or park, wheels blocked, etc) bring engine RPM to 4K and the PCM immediately takes control of injectors, engine speed drops, and it's done. Literally less than 2 seconds. An honest shop would charge .5 hours labor or less.
Old May 15, 2016 | 01:55 PM
newguy's Avatar
Capable scan tool would cost how much
Old May 15, 2016 | 02:23 PM
Ask Les Myer, he found a set up that isn't all that expensive. There are always used scan tools on Ebay too. Usually start around $1500, but you need to make sure the software is updated to cover your year of vehicle, and that it has the accessories that you'll need, (cables, connectors, adapters, etc).
