case relearn
Old May 17, 2016 | 09:27 PM
  #21
newguy's Avatar
Actually no light at initial start up
Old May 18, 2016 | 08:51 PM
  #22
newguy's Avatar
Originally Posted by Captain Hook
Bingo! Piece of cake. Now check out camshaft retard and adjust if necessary. I think you'll find it under the "Misfire" menu, all the way at the bottom.
Captain, will this affect my pcm tune?
Old May 19, 2016 | 07:31 AM
  #23
It will not affect the settings that you programmed. It will assure that they are applied correctly, which may make a noticeable difference in performance, if the relearn data was incorrect.
Old May 19, 2016 | 07:41 AM
  #24
LesMyer's Avatar
So Captain, have you have success completing CASE relearn with SES light on with misfire code at start of procedure? This is for my own personal info.
Old May 19, 2016 | 03:46 PM
  #25
Les, to be quite honest, I've done that procedure countless times over the years, and I really can't remember if the SES light was on or not, or if they had any DTC's in memory. I can tell you that every one was successful.
Old May 19, 2016 | 09:28 PM
  #26
LesMyer's Avatar
I think that answers my question. FYI at one point on mine I had difficulty getting the fuel cutoff to happen with my software. Bet it works better with Tech 2.
Old May 19, 2016 | 10:40 PM
  #27
newguy's Avatar
The first time I did this one I didn't use two feet and took my foot off the brake to raise the rpm s . Brain fart
Old May 19, 2016 | 11:21 PM
  #28
newguy's Avatar
joey
Aug 27, 2012 06:33 PM
Klturi421
Jun 10, 2012 03:45 PM
GM hater
Jan 9, 2010 02:32 PM
chevcamls1
Jan 15, 2008 06:50 PM
rob2129us
Jan 9, 2008 07:16 PM
