cat breaking up?
Old Jul 27, 2010 | 10:29 PM
98blazermark's Avatar
98blazermark is on a distinguished road
Default cat breaking up?
i just got a 98 4x4 blazer and doing a bunch of work to it.
the list so far:
-resoldered wiper control module
-reconnected rear washer fluid lines
-new rear driver caliper
-new pads on rear
-new rotors on rear
-new driveshaft ujoints
-recharged the a/c
-intake gasket changed
-thermostat changed
-4 new shocks
-new idler arm
its in really good condition for a NY truck. no body rust, and even underneath its in good shape.
i have a few things left,
-ball joints,
-catalytic converter.
the cat is doing something wrong... its rattling, like the whole honeycomb because disloged from the metal frame. has anyone heard of this? no cel or anything, just the annoying rattle at idle in drive. give it a little gas it does away, but have someone in the truck idle in drive and hold the brake and get under the truck, its right in the cat.
I have 2 options for repair
- cut just the cat out and weld in a generic cat.
or buy the cat assembly and bolt the whole thing in. I have found them for under 180 bucks shipped. not sure what direction to go
Old Jul 27, 2010 | 11:01 PM
old skool luvr's Avatar
with what? which cat to use?
generally, the uni-fit cat's tend to not be a simple bolt (weld) in. always something that needs messed with.
a direct fit is usually the best bet. i say "usually" since there is always a chance your application may be the one unusual application.
mind you......i did have one of those uni-fit cat's fit like a glove. once.
Old Dec 22, 2010 | 11:28 PM
rwd681's Avatar
rwd681 is on a distinguished road
I have the same problem occuring in my 97 s-10 4x4 blazer. I'm at about 235,000 miles. What is your milage?
Old Dec 23, 2010 | 12:28 AM
UberFail's Avatar
UberFail is on a distinguished road
my jimmy has about 180,000 miles on it and the cat was completely empty.... i put a bolt in and even that wasn't just bolt in. had to cut all the bolts out and replace them all for the new cat to bolt up - pressed studs just don't last on exhaust parts :/
Get the bolt in tho it'll save you a bunch of hassle in the end.
Old Dec 23, 2010 | 06:28 AM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Heard of it hundreds of times. Get the exact fit-save yourself alot of time and issues. Done deal. Merry Christmas-Jerry PS $180 for (if it is) a brand name-exact fit is a good price.
Old Dec 23, 2010 | 10:34 PM
since OP has only posted twice, i wonder what his final outcome was?
hillbillys10
Apr 14, 2013 01:04 PM
Squad-6
Headers, Intake, & Exhaust
May 17, 2011 10:29 PM
Bullfrog2099
Dec 16, 2010 07:25 PM
PaulO2288
17
Jan 20, 2010 01:39 PM
djbass_mekanik
Apr 22, 2006 06:15 AM
