Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Replacing cat, front of old cat is stuck on truck
Old May 17, 2011 | 01:59 PM
Squad-6's Avatar
Squad-6 is on a distinguished road
Question Replacing cat, front of old cat is stuck on truck
My old cat is blocked up so picked up a higher flow one to replace it with. Got the rear of the old cat free from tailpipe & muffler. Got the front of the cat free from the crossmember brace & took off the U bolt. Banged on cat with rubber mallet & even tried a come along until I was afraid of breaking the exhaust manifolds. No room to cut it off & have enough straight pipe to put a new cat on. I also do not own a torch of any kind. So anyone got any thing I should tried to get the old cat pulled off?
BTW the vehicle is a 85 S10 Blazer 4x4 with a 2.8
Old May 17, 2011 | 02:08 PM
When it comes to exhaust pipes that are held together with an exhaust clamp (u-bolt & saddle), they can be a major pain to get apart. I would recommend finding someone with a small grinder and cut grooves in the cat's inlet pipe just deep enough to go through the cat and not into the y-pipe.
Old May 17, 2011 | 02:54 PM
Squad-6's Avatar
I will borrow a grinder from work. Thanks!
Old May 17, 2011 | 03:02 PM
A thin cutoff blade will make the job easier and faster!
Old May 17, 2011 | 04:49 PM
xgiovannix12's Avatar
when i got my cat replaced i cut it off with a plasma cuter LOl . worked out great
Old May 17, 2011 | 10:29 PM
Rottidog's Avatar
Yup, backyard mechanic style - cut horizontal slices along it but not through the Y Pipe & get at the "slices" with a ball peen hammer & a cold chisel & PEEL it off the Y Pipe.
OR take a reciprocating saw, cut it off at the end of the cats tubing, get whatever you'll need for length of 2-1/2" from a muffler shop (I think thats the diameter) exhaust pipe, 2 extra bar & saddle clamps, have that muffler shop enlarge the pipe at the ends so the ID - interior diameter will fit over the OD - Outside diameter of the existing exhaust pipe. Clamp it all together. They'd probably enlarge the ends for nothing & the 4" or ? you may need might cost you $5.
If you have other transportation cut it out at the ends of the cat & head to a muffler shop.
SyberTiger
Aug 8, 2014 10:08 AM
davtak
Sep 17, 2013 08:02 PM
mikepro
Aug 15, 2011 07:03 PM
kwikshifter
Jul 16, 2010 01:35 AM
88s10Blazer
Dec 22, 2009 05:50 AM
