Catalytic Converter
Old Oct 9, 2012 | 04:17 PM
nickzaw's Avatar
nickzaw is on a distinguished road
Default Catalytic Converter
It is getting to the point where I can not hold off on getting a new catalytic converter any longer on my 2000 Blazer LS 4x4.
I purchased one a couple months ago from magnaflow that said it was the right diameter for my truck and I ended up getting a 3 in. cat when the actual exhaust is 2.5 in.
On every website I enter the details of my vehicle in, they give me the same size magnaflow gave me.
So I was wondering which size cat I should purchase and could someone possibly supply me with a link to the actual product?
Thanks!
Old Oct 9, 2012 | 08:57 PM
motorcity blazer's Avatar
motorcity blazer is on a distinguished road
Try rockauto they have a drop in cat that bolts right in. It was around $150 which is pretty good.
Old Oct 9, 2012 | 10:23 PM
Rottidog's Avatar
A 2nd gen has a 2.5" exhaust from what I've seen (had mine rebuilt so I'm not sure what was original). From what I've read online some say 2.5" intake on a muffler & 2.25" on the out side of it. Why Magnaflow says & sent a 3" I have no idea unless the wrong parameters were put in or it's an aftermarket size.
Most of the Google shows up with BlazerForum links... so search us out!
And I agree with checking out rockauto for a stock replacement or at least knowing the size.
Old Oct 10, 2012 | 12:09 AM
50lb_cat's Avatar
Or, if you can weld or know someone who can, just get a hi flow off ebay and grab some spark plug non foulers for the downstream o2 sensor.
Old Oct 25, 2012 | 08:27 AM
Tony H's Avatar
Tony H is an unknown quantity at this point
I'm looking at a new Cat for a 2002. same thing, all the Universal fits for that year have
3" ID IN and OUT Not sure how that Rock Auto one works since my cat is all part of the 'Y' Pipe. no flanges or clamps. I have to get inder teh car and measuer the OD of my pipes to see if it will fit tight enough to weld all around to close it up.
50lb_cat is this the guy??? Oxygen Sensor Fitting with adjustable jets : BoostController.com LLC - America's Source for High quality turbo boost controllers, silicone hose, and more performance products - 877-836-6155- precision boost control. Turbosmart Warehouse Distributor
Old Oct 25, 2012 | 12:00 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default My 2cnd gen
Has a 3" exaust from the converter to the muffler.Anyway you can have it welded on with a reducer or expander?
Old Oct 25, 2012 | 12:11 PM
Tony H's Avatar
I measured a 2.1" front and a 2.25" back of the existing pipe. Of course I can weld this on just wondering why they specify these Converters for this car but they really don't fit. A Converter with a 2.25" front and 2.5" rear would be a lot closer and Clampable or weld without filling gaps or buying additional sleeves to take up the gap.
Old Oct 25, 2012 | 12:26 PM
50lb_cat's Avatar
http://www.autozone.com/autozone/par...er=720805_0_0_
All they do is raise the o2 sensor out of the stream so it reads more clean air, that way you won't get a CEL.
Old Oct 25, 2012 | 12:30 PM
Tony H's Avatar
Originally Posted by 50lb_cat
Dorman/Spark Plug Non-Fouler (42006) | AutoZone.com
The thread size is the same as Plugs as it is for teh Rear O2 sensor? no
The one I showed is specific for O2 sensors and it did the job on my sons Subaru. very borderline finicky After Cat sensor.
Old Oct 25, 2012 | 12:43 PM
50lb_cat's Avatar
I've used the dorman product in the past, it will do the trick. The product you showed looks like a better product for sure lol. Just depends on how much you want to spend.
88s10Blazer
Sep 21, 2007 06:50 PM
dragon954
Jan 6, 2007 07:33 PM
sgtbrum
Dec 18, 2006 11:29 AM
88redk5
Headers, Intake, & Exhaust
Oct 26, 2006 06:24 AM
Mbastet99
Aug 25, 2006 09:34 PM
