Changing the headlight bulbs on a 97 Blazer
Old Mar 16, 2008 | 05:22 PM
jonesjamesw's Avatar
jonesjamesw is an unknown quantity at this point
Default Changing the headlight bulbs on a 97 Blazer
Can anyone tell me how to change the headlight bulbs on a 97 Blazer? Thanks!
Old Mar 16, 2008 | 05:23 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: Changing the headlight bulbs on a 97 Blazer
do you have your owners manual?
Old Mar 16, 2008 | 05:33 PM
Yes-
Will it tell me how? Looks like I need to pull out the grill.
Old Mar 16, 2008 | 06:54 PM
For composite headlamps:
Remove of Disconnect:
1. Plastic Caps that cover the headlamp retaining pins.
2. Headlamp retaining pins.
3. Headlamp from the vehicle.
4. Bulbs from the headlamp by pushing in and rotating them 1/4 turn counterclockwise.
Install or connect:
1. Bulbs to the headlamp by pushing in and rotating them 1/4 turn clockwise.
2. Headlamp to the vehicle.
3. Headlamp retaining pins tightened to 62 lb.in. (7 N-m)
4. Plastic caps that cover the headlamp retaining pins.
For sealed beam headlamps:
Remove or Disconnect:
1. Screws that retain the headlamp retaining ring.
2. Headlamp retaining rings.
4. Headlamp electrical connector.
Install or Connect:
1. Headlamp electrical connector.
3. Headlamp retaining rings.
4. Screws that retain the headlamp retaining rings.
The '97 is one of those years that a lot of people ask questions about. If you have the composite headlamps and wouldn't mind snapping some pictures of the plastic caps and the retaining pins, I'm sure that would help out a lot of people in the future! Thanks!!
*EDIT* - Also listed in the owner's manual page 6-33 thru 6-35.
scblazer
May 27, 2007 11:52 PM
EuroGoldLS
Apr 14, 2007 08:24 AM
bluesjam99
Feb 17, 2007 03:34 AM
blazinloud
Jan 6, 2007 03:55 PM
dropd4door
Jan 30, 2006 06:18 PM
