Changing Thermostat on 2000 Blazer
Old Oct 28, 2005 | 12:27 AM
Weshard's Avatar
Weshard is an unknown quantity at this point
Default Changing Thermostat on 2000 Blazer
I have not worked on a car for 20 years so things are different... I need to replace the thermostat but can't find a drain on the bottom of the radiator. Is there one? Is there another way to get the fluid down so I can replace the thermostat without flooding the drive? Weshard
Old Oct 28, 2005 | 01:26 PM
tdannar's Avatar
tdannar is an unknown quantity at this point
Default RE: Changing Thermostat on 2000 Blazer
On my 98 4X4, the drain for the radiator is on the passenger side, on the back side of the radiator (facing the engine), not on the bottom. On my 4X4, I can only access it from the top side due to bash plate. On my 4X4, there is a drain hose connected to the drain. Nice set up, doesn't get all over the place when draining. It is a plastic drain plug that makes about 1/2 to 1 turn and stays on the radiator.
TD
toms2000blazer
Dec 20, 2015 07:23 PM
oem95blazer
May 28, 2014 03:09 AM
R134A
Jun 1, 2010 06:21 AM
pigmak
Aug 14, 2009 09:41 AM
CKSMartin
Feb 24, 2005 02:39 PM
