oil cooler lines
Old May 8, 2005 | 12:06 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default oil cooler lines
you know how these things are notorious for leaking, right? well i just replaced mine and it sucked! i wouldn't even try it with out a lift handy. just thought id let you all know. at least there won't be any more oil spots in my driveway.
Old May 8, 2005 | 12:16 AM
timetoblaze's Avatar
timetoblaze is an unknown quantity at this point
Default RE: oil cooler lines
i think that lifts are the best inventions ever lol
Old May 8, 2005 | 10:23 AM
zero psi's Avatar
Retired Admin
yeah, they definatly spoil you
Old Aug 17, 2005 | 01:54 PM
99blazingred's Avatar
99blazingred is an unknown quantity at this point
My oil cooler line to the engine is leaking also. I have ramps but no lift. How hard do you think it will be to do the repair using the ramps?
Any hints on replacing them.
thanks,
Old Aug 17, 2005 | 03:44 PM
Hanr3's Avatar
Did you go with OEM replacements or something else?
Wish I had a lift in my garage.
Old Aug 17, 2005 | 05:15 PM
I havent bought them yet but I am planning on OEM.
Old Aug 17, 2005 | 11:26 PM
zero psi's Avatar
Retired Admin
ORIGINAL: 99blazingred
thanks,
it wont be much worse, you may get an oil shower though. use a really long 3/8" extension with a swivel to get to the bolt at the back of the motor. and definatly go with the OE parts. after i did mine using a/m, a couple of the seals started leaking. i replaced the seals with OE and it sealed. they are pretty straight foward, its just the rear fitting that sucks. that was on a 95, they may be different on a 99.
Old Aug 19, 2005 | 04:56 PM
Hanr3's Avatar
Reason I ask. I have heard of guys replacing the OEM stuff with regular fittings. They split the metal pressed clamp fitting on the OEM hoses, peel it back and pull out the OEM fitting. Basically taking the fitting off without cutting the hose. Then slide the OEM hose over regular barb fitting and using pipe clamps to hold it in place.
Old Oct 28, 2005 | 04:45 PM
nslide10's Avatar
nslide10 is an unknown quantity at this point
i eliminated the oil cooler all together i have a 96 4wd an d i bought the nipple for the 2wd that goes where the cooler does off the block so now i just put my filter where the cooler went. i have to use a shorter filter now and its a lil harder to change but i dont have to use that damn oil cooler and all its leaky lines plus when i changed the engine they said id have to get a whole new oil cooling system because u cant flush all the contaminent out of the old one enough to ensure u wont damage the new engine with old crap
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
ComputerNerdBD
26
Nov 10, 2009 12:21 PM
Jetfixer
Jul 11, 2006 05:02 AM
eng69
Jan 31, 2006 04:55 PM
