chasing a gremlin
Old Jun 10, 2016 | 06:21 PM
newguy's Avatar
Default chasing a gremlin
2000 zr2. new stuff. Headers, coil wires, plugs, skip white distributor. relearn done, timing set. ac delco cap rotor, plugs.
Now the gremlin Start up runs idles great, when it gets up to full temp I have a random skip/miss. solus pro shows no misfires. took off throttle body and looked for washed down intake, nice and black, all good there. did a leak down, 60 psi and held steady for 20 minutes.
Next try. what I`m thinking is since it doesnt do it till fully warm maybe its a lazy o2 sensor. Any thoughts any one?
Old Jun 11, 2016 | 04:53 PM
Could be a lazy O2, but you would see that in the data stream. On your Solus Pro, graph both upstream O2's and watch how they perform. Sweeps should be nearly identical.
You mentioned that you had a relearn done. That procedure is for the crankshaft position sensor, and the data needs to be correct. Installing a distributor on the other hand, requires camshaft retard to be checked and adjusted if necessary. This is an adjustment, not a relearn. If camshaft retard is out of spec, there will be crossfire going on inside the distributor cap, guaranteed. Depending on how severe the misfire is, it might not set a DTC.
The PCM uses combined data from the crankshaft position sensor AND the camshaft position sensor to detect, and accurately identify, cylinder misfire. If the crankshaft position sensor relearn data, or camshaft retard adjustment are incorrect, cylinder misfire data could be nonexistent or incorrect.
Old Jun 11, 2016 | 05:30 PM
newguy's Avatar
Both crankshaft data and cam retard are correct. already got the o2 sensors. will change when rain stops. probably original anyway and may help mileage. I keep going back to why when its fully warm and not when cold
Old Jun 11, 2016 | 05:50 PM
Could very well be lazy O2's. The PCM ignores them in open loop operation.
Old Jun 11, 2016 | 06:00 PM
newguy's Avatar
We will see, I`ll post results
Old Jun 11, 2016 | 06:04 PM
AC Delco or Denso, stay away from Bosch, (response time is too slow).
Old Jun 11, 2016 | 08:17 PM
newguy's Avatar
ordered from rockauto, was supposed to get them today, they didt show. sighh https://www.rockauto.com/en/moreinfo...=1361461&jsn=1
Old Jun 11, 2016 | 09:52 PM
Good job! Those will work just fine.
Old Jun 14, 2016 | 04:00 PM
newguy's Avatar
Bingo, cured the issue.
Old Jun 14, 2016 | 04:02 PM
Yee Haa!
FX4DOOR
Jan 20, 2014 11:22 AM
betamatt76
Jul 17, 2013 06:39 PM
TDS-MN
Apr 23, 2012 03:58 PM
sxa3310
Dec 29, 2011 06:42 PM
2tone2g
May 31, 2011 09:37 PM
