Chasing Sparks
Old Jan 20, 2014 | 09:10 AM
FX4DOOR's Avatar
FX4DOOR is on a distinguished road
Default Chasing Sparks
Looking for some assistance, I have a 1976 K10 I am restoring and I am having issues with the turn signals. As soon as I put power on with the key all turn signals flash. I can pull out the relay (both are new) and it quits. all the other lights work just as advertised. I put the turn signal relay back in and back to all flashing. I can turn on the LT or RT turn signal and it works like it is supposed to and the opposite side will quit flashing but it goes right back to all flashing when you return to the neutral position. I have added an additional ground from the engine to the frame. I have pulled all the assemblies out and made sure they have good grounds. I have used almost an entire can of contact cleaner on the fuse block and taken it apart at the fire wall, cleaned and re applied dielectric grease, still the same. About to loose my mind and start driving with my arm out the window to signal.
Old Jan 20, 2014 | 11:22 AM
Thogert's Avatar
I know on the S10s the hazard switch can go bad and cause this. I'm not sure about the K10s though.
betamatt76
Jul 17, 2013 06:39 PM
TDS-MN
Apr 23, 2012 03:58 PM
sxa3310
Dec 29, 2011 06:42 PM
2tone2g
May 31, 2011 09:37 PM
pigmak
Jun 22, 2008 02:47 PM
