Cheap way to read Camshaft Retard
#31
Oh well. I'll see what I can do with the terminal app and dig around on it. I am going to pull the TCCM later and see which one it is, as Rockauto lists several models as compatible for the Bravada. If they are similar then I would suspect that some of the diagnostics would be very similar.
#32
You'll need to make sure the Borg Warner transfer case is compatible with your TCCM and wiring. Standard transfer case in your 2001 Bravada is NV, (New Venture) and there are differences. Don't want to get off topic in this thread, if you want to discuss it more, you need to start a new thread
#33
I have been playing around a little more with Car Gauge Pro as this post has caused me to get interested in it again. Here are some gauges I am able to get some data from using the Powertrain Module:
Last Shift Time ( in seconds)
Torque Converter Efficiency (in percentage)
Transfer Case Ratio (in degrees - I see from 0.2 to 0.5 regularly)
Transmission Fluid Temperature (in degrees)
Slip Counter (number)
Intake Air Temp (in degrees)
Fuel Tank Capacity (in gallons)
Very happy with some of the transmission stuff, including the temp.
I'm with you Les, I have been unable to get anything to work in any other module. The transmission ones surprise me a bid, and the fact that there is a transfer case ratio says there is some communication there (albeit if its anything of substance remains to be seen).
On the Activate Components portion in Diagnostics, I have been able to turn the fuel pump on and off, and when I tried to trigger the ABS light, it would turn the Service Engine Light on and off.
#34
Thanks for the input
You do know that you can easily look at a table of multiple PIDs in diagnostics without making a gauge, but only after you are connected to the vehicle does the choice come up?
If you try the GM transfer case module, Car Gauge Pro finds the TCCM at the correct address but none of the PIDs work.
I did download a couple of Android terminal apps and can connect to the bluetooth OBD2 device and send the standard ELM327 commands to the computer and get back a response, but I have not yet figured out how to enter the hexadecimal commands to get responses for retrieving/clearing transfer case codes like I did in ScanXLPro on my laptop using the USB OBDSX device. I did have to select custom terminal in Scan XL Pro. Something about the format the commands are in it seems. I'm not enough of a computer geek to easily figure it out. Anyone out there know what my problem might be? I did find your Olds listed together with the 4-button Blazer for codes on the Dorman site, so I think retrieving/clearng TCCM codes are probably the same. Diagnosis charts should be similar but undoubtedly with some differences.
#35
Yes, I saw the table of PID's in diagnostic....I am pretty visual though so I tend to stick with the gauges
I noticed that with the Transfer Case Module...surprising that it some TCCM functionality is in the Powertrain module, however again what the data actually points to is up for debate at this point. I plan to try some of the terminal apps this weekend when I can sit in there and work on it.
I think we are at that stage with these 2nd gen blazer/bravadas that we can get just enough cool data to wet our appetites and do a lot, but not enough to do EVERYTHING we want without more costly apps and options...course that's me just being greedy I suppose.
#36
#37
I started out with Torque Pro, which is a pretty nice little app in itself. I have three softwares that will do cam retard on the Blazer (Car Gauge Pro, Scan XL Pro, and HP Tuners). Only HP Tuners with it's proprietary interface will do the crank sensor learn, injector balance tests, control the transmission, turn things on/off, etc on the Blazer. They cost $8.95, $150, and $350 respectively.
The functionality of CGP and Torque Pro (have both) on the go is awesome for on the spot diagnostics, but I am not opposed to having that deeper level of functionality. Can it control the transfer case at all?
#38
HP Tuners has piqued my interest. Do you feel that it was worth what you paid for it? I see if on Summit's site for $349 (can't get to the HP Tuner site as I am at work and its blocked - guess I should be working). I plan to keep my Bravada as long as possible as my father in law bought it new and I got it from him in 2011. I still have the original window sticker for it and its in great shape overall, but getting the normal bugs that would come up on a 15 year old vehicle with 270k on the clock.
#39
Quick and Dirty How to make Dashboard Screens
* Connect/GM Powertrain/Full Auto Scan/OBDII/select the shown address
* Let software scan the available PIDs
* Save PIDlist to a filename of your choice.
Now you don't have to be connected to the vehicle to do the rest so disconnect and go back into the house.
* Connect/GM Powertrain/no scan/import PIDs /import from file/select your PIDlistfilename
To make a CMP Retard gauge like mine
Select Dashboard
* go to a blank page
* tap in top right corner of the screen
* select add gauge
* select CMP Retard* from available PID list
* Check Digital
* Select Add
Then to make a misfire counter like mine
* select Misfire #1 from available PID list
* Select Add
Repeat last steps again for each of the other desired misfire counters
When done hit your back button on your phone and the Add gauge screen will disappear.
Press on a gauge you wish to move until Display config appears.
* select Drag and Move
* Drag the gauge to the position where you want the gauge on the screen.
Repeat until you have the gauges where you want them on the screen.
To save your profile, touch the top right of your screen, select Guage profile/save/tell it where to store it/type in a name/hit save.
Now you can select from multiple gauge profiles by name by touching the top right of the screen, selecting gauge profile, and recalling the file.
Select Dashboard
* select add gauge
* Check Digital
* Select Add
* Select Add
I am not doing something right, because the only gauges that it shows under added pids is RPM (1) ECT (2) IAT(3). when it scans for available PIDS it doesn't show the cam retard, and I am not sure of how to save the PID list. Any help you can give me would be great.
#40
I don't know how to make this any clearer.
I guess I did forget to state that when you go back in the house to build your gauges, you need to first:
* Connect/GM Powertrain/NoScan/IMportPIDs Offline/Import from file/select your PID file......... Then open dashboard. Now all the available PIDs should be under Available PIDs.
After you have built your gauges, you save the gauge profile to a file and you can always easily recall it.
Hope this helps. If all else fails, PM me and we will go through it together on the telephone during an evening.
