check coil
Old Oct 10, 2013 | 07:16 PM
blazerontwenties's Avatar
blazerontwenties is on a distinguished road
Default check coil
How do you check the coil on 01 blazer
Old Oct 10, 2013 | 09:18 PM
spittybays
Guest
Posts: n/a
Your ? really begs for another ?. What's going on, if your looking to see if your getting spark or trying to find out if your coil is going bad. To see if you have spark just take the coil wire off the distributor, stick a screw driver in it and hold it close to a ground. Hold the insulated end of the screw driver and have someone give it a crank. You should see spark. If no spark somethings wrong between the key and the coil.
Here is some very good basic stuff. Keep in mind it's kind of rare to have a bad coil.
Old Oct 11, 2013 | 08:20 AM
chris015's Avatar
another way is too pull the plug wire on it off,then sit it back on the stud,but dont push it down. leave it kinda sideways so you can see the inside. Have someone turn the truck over,see if you see a good spark jump and a good tick.
blainenbecky
Mar 9, 2013 10:38 PM
Lancealot
Feb 22, 2011 07:34 AM
ivannj
Jan 13, 2006 08:18 PM
bjam2
Dec 3, 2005 12:39 AM
02 Vortech
Apr 14, 2005 11:53 PM
