check engine and abs/brake lights
please help - P030x, P1638, P1637 and C0265 frustrate me
Hi all together,
My baby is really in need: I tried to find a workshop with experience for my 2001 Blazer but here is nobody. Not even the GM dealer can help and I am always lucky if I get her out of the workshop with less malfunctions than she had before. Also it takes weeks so that it's better to say "change this and this and be careful with this here and there..." It's a headache.
Since a few weeks I have trouble with the ignition between 2500 and 3000 RPM: Ceck Engine light flashes for few seconds and I got these codes:
P0305 - Cyl.5 Misfire
P0300 - Random Misfire
P1637 - Generator F-Circuit Terminal
P1638 - Generator L-Circuit Terminal
but there is no abnormal noise or stutter...?
When the Engine is hot, ABS and handbrake lights stay on and I get the code
C0265 - EBCM Motor Relay Circuit (Dealer comment after they changed the whole handbrake(): "We can't repair this. Your car is too old...Wouldn't you like to buy a new..." ...And it pains again... )
The lightshow is perfect on the highway: ABS and Brake, Engine light and Overspeed flashing one by one... - -
I really don't know what next. Have changed battery, alternator, spark plugs and cables. Compression in the cylinders is ok, too.
What would you try next: crankshaft sensor, ignition switch, distributor, PCM, coil, EBCM?
Greets - hirni
Greets - hirni
C0265/C0266 - EBCM Motor Relay Circuit - you'll likely be looking at a rebuilt EBCM - There is an online rebuilding company that others have commented on as being very good, but I cannot remember the name of it at the moment.
P030x - Random/Multiple Cylinder Misfire Detected - There is also a quite extensive thread on this. A search will turn it up.
P1637 - Generator L-Terminal
P1638 - Generator F-Terminal
Run through the testing required to diagnose this code. If you need the general charging system tests, let me know.
In response to your PM, I created the following post in the Tech Article (DIY) section:
Charging System Test (book methods) by swartlkk
Hi Swartlkk,
Thanks so much. It's nice to have now.
This weekend I'll check the charging system and keep the forum informed.
Great job, man!
Update: Just got an EBCM from the butcher. Ok, it looks like one for the GMC Yukon...but it fits perfect and I made some emergency stops on these silted desert roads here: It works well since 150km. My Lightshow gets smaller...
Greets from Arabia - Hirni
Great job, man!
the only fun this weekend - i take it sarcastic
My mechanic was rebuilding his workshop this saturday so he sent me to an electrican to find out what's on with the charging system.
Nice:
He had no scan tool and he replaced the Electrifyer without any result.
And he replaced the distributor cap without any result.
My Engine sounds a bit knocking and I am tired of this wasted money and time...
The only useful thing what happened today: I asked the butcher for a used alternator for a test run and he agreed. Will give this a try next weekend...
Greets from the dry desert grounds
Nice:
got it now - except P0300x...
Ok, so far, on sunday I visited the electrican again at 7AM before my working time starts. He exchanged the regulator of my alternator in 15min and since then I have had no charging problems.
Now it's time for P0300x which still occurs between 2500 and 3000 RPM.
I already ordered a new distributor from your continent.
Should arrive here next days...
Greets - hirni
Greets - hirni
Hi Swartlkk,
the distributor was not the problem. I still have misfire after replacing it.
Last time on two trips the engine was stuttering a bit. It happens not always but I have to solve this. It really hurts me, when the engine is running like this.
I will go to the workshop again tomorrow. Do you think it makes sense to change the crankshaft & camshaft sensors?
Greets - hirni
Greets - hirni
