Check engine light on
Old Jan 15, 2009 | 12:06 PM
Default RE: Check engine light on
The EVAP system is a pain to deal with. While you can run functional tests with a scan tool, usually a smoke machine must be used to determine if there is a fault. The Vent valve will usually fail to close properly. This can be bench tested with a 12V power source. Just check to see if it holds a seal. I cannot remember if it seals when energized or when de-energized.
zombiewoof
Feb 1, 2009 12:06 PM
zoniah
Jun 2, 2008 08:45 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
