Check engine light and high Idle Speed
Old Sep 20, 2008 | 02:24 PM
Kraked Jack's Avatar
Kraked Jack is an unknown quantity at this point
Default Check engine light and high Idle Speed
Okay so its a 95 blazer 4x4 4.3L vortec 6 runs great.... then check engine light comes on and revs to 2000 rpm?? its a 1995 so i figure its an obd 1 but it has a 16 pin connector ?? if i flash the ecm by pulling the fuse for ecm/batt check engine goes away runs fine until light comes on again! sounds like a egr valve to me? so i bought a haynes manual and it does not show the egr valve for my engine? ugh i am mechanicaly inclined but this thing has me at wits end!!!!!
please somone explain a little bit to me before i replace O2 sensors mass flow sensors !!! and a egr valve
Old Oct 12, 2008 | 09:59 AM
Default RE: Check engine light and high Idle Speed
[align=left]Never mind a TPS from the ole boneyard did the trick (but thanks for the help anways
[/align]
berniescout
Feb 21, 2012 04:48 PM
DaveHearne
Apr 30, 2010 11:27 PM
94pos
16
Jan 9, 2009 06:44 AM
Deezy
Oct 25, 2007 08:58 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
