Check Engine Light S.O.S.
Old Apr 1, 2008 | 05:35 PM
BlackBlaze's Avatar
BlackBlaze is an unknown quantity at this point
Default Check Engine Light S.O.S.
I have a '99 blazer and the check engine light came on. i fixed the problem it was just the MAF sensor so i cleaned that off but i have no idea how to make the light turn off. please help.
Old Apr 1, 2008 | 05:39 PM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
Default RE: Check Engine Light S.O.S.
You need a Diagnostic Code Reader. Go to your local Advance Auto Parts store and they can read it and clear it for you. It's free and should take no time at all
Old Apr 1, 2008 | 06:18 PM
BlackBlaze's Avatar
would they be able to do that at any auto parts store. i dont have an advanced auto parts near my house
Old Apr 1, 2008 | 07:12 PM
They can clear the codes at the parts store. You could also just let it go out on its own if you fixed the problem. It'll do so after a few drive cycles have been completed.
Old Apr 1, 2008 | 07:45 PM
BlackBlaze's Avatar
thanks for the help
Old Apr 1, 2008 | 08:30 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
disconecting the battery sometimes works
Old Jun 5, 2008 | 03:13 AM
driven's Avatar
driven is an unknown quantity at this point
I have tried that once but disconnecting and unplugging the battery didn't work. I guess it depends on the car, is it?
Old Jun 5, 2008 | 08:02 AM
MikeInCtown's Avatar
MikeInCtown is an unknown quantity at this point
Disconnecting the battery negative for 30 seconds should work. if it doesn't then you still have a problem. As also said, if the problem was fixed the light should go out on it's own. If not, then you probably still have a problem.
Old Oct 12, 2008 | 10:02 AM
Kraked Jack's Avatar
Kraked Jack is an unknown quantity at this point
You could pull both ecm fuses and count to 10 and toggle the ignition 5 times that usually does it (workd on mine)
Old Oct 12, 2008 | 11:33 PM
JerzeyLegend's Avatar
JerzeyLegend is an unknown quantity at this point
Yea, don't you have to put it in ignition, and press the brake pedal 5 times, then start the car?
Just disconnect the battery overnight. When you come out in the morning your light will be off. If the problem exist, it will come back on when the problem occurs.
I have a bad air pump. The SES light will stay off after erased, however once the engine cools, it has to use the air pump again which will cause the light to come on.
In the codes explained, it says it will turn off after the problem is fixed, and 8 drive cycles.
Look up your code to see how many cycles before your SES lamp turns out.
zombiewoof
Feb 1, 2009 12:06 PM
zoniah
Jun 2, 2008 08:45 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
