chevy blazer please help
Old Jul 18, 2010 | 04:23 PM
LLS88's Avatar
LLS88 is on a distinguished road
Default chevy blazer please help
i have a 2002 chevy s-10 blazer i have replaced fuel pump fuel filter plugs plug wires rotor button distributor cap camshaft position senser crankshaft position senser and spider injectors unit but still won't run it starts for about
5 seconds if i hold the throttle paddle to the floor and pump the throttle but then stalls i have checked the security system its off so thats not it what else could it be thanks for any help
Old Jul 18, 2010 | 04:28 PM
TripleBlackBlazer's Avatar
**Moved to 2nd Gen Tech**
The New Member area is for introductions.
Old Jul 18, 2010 | 05:29 PM
BAGnDRAG-K5's Avatar
BAGnDRAG-K5 is on a distinguished road
OK first of all is it putting any codes up? If not then you will need to consider either the computer or the problem is actually mechanical. Are you getting fire? Have you checked the ignition module? Are your coil packs operating? Have you checked any of your relays and fusses? I know stupid simple but sometimes overlooked. I always try to diagnose the stupid simple stuff first. OK check any of these that you have not allready tried. Let me know if any of these help.
Old Jul 18, 2010 | 05:45 PM
Sounds like the passlock system is activating and shutting down the engine. Have you tried the passlock relearn procedure (search "passlock+relearn" without the quotes)?
Why did you replace all of those components??
Old Jul 18, 2010 | 05:53 PM
Good call on the pass lock system, I forgot about that. This (among other reasons) I went back to an old school truck!!
Old Jul 18, 2010 | 06:02 PM
It is possible that the ignition switch is to blame. The passlock sensor is part of the ignition switch.
Old Jul 18, 2010 | 09:41 PM
LLS88's Avatar
Default Lls88
the plugs are firing i checked the timing chain its good shape i checked the security lock its not on i checked all fuses it started over the corse of about two weeks it got slower and slower not wanting to pull hills very fast then just quit all together i changed the fuel pump in stead of checking it i know i should have got up under there and checked it but listening to someone else that told me that was the problem was a mistake i changed the spider injector unit i thougt this had to be the problem i was wrong every thing i have done to it still no change i really wish i could figure this out any help would be great!!
Old Jul 18, 2010 | 09:47 PM
How did you check the timing chain? and security lock?
Old Jul 19, 2010 | 12:23 AM
LLS88's Avatar
i took the timing chain cover off the chain and sprockets looked good i checked the security lock in the radio it said security system disabled
Old Jul 19, 2010 | 12:32 AM
You do not check the passlock system with the radio...
Did you try what I first suggested?
