Clean Vacume lines?
03 Blazer, 4.3 auto, 4X4 Had a problem on the road that chewed up the gear on the right axle shaft in the front Diff. Reading the post I determined the problem started with the vacuum switch on the transfer case and when I pulled the connector off I found ATF in the lines, have not checked the oil level in transfer case yet as I had a thunder storm roll thru and the shade tree leaked. How do I go about cleaning the lines out?
TIA
Jim
TIA
Jim
Wonder no longer... Found using the search feature for 'clean+vacuum+lines' - 8th thread down the list:
There are other, older responses that say very much the same thing as well, that I am sure of.
If you haven't already, I would flush all of the vacuum lines out with a mild degreaser like Simple Green followed up with blowing them out with compressed air, rinse, & repeat as necessary until they are all clean. If you don't get the fluid out of there, you could trash the new actuators again.
dillon
19
Jan 16, 2011 07:36 PM
