Clean Vacume lines?
Old Jul 18, 2012 | 03:58 PM
Blue Jay's Avatar
Blue Jay is on a distinguished road
Default Clean Vacume lines?
03 Blazer, 4.3 auto, 4X4 Had a problem on the road that chewed up the gear on the right axle shaft in the front Diff. Reading the post I determined the problem started with the vacuum switch on the transfer case and when I pulled the connector off I found ATF in the lines, have not checked the oil level in transfer case yet as I had a thunder storm roll thru and the shade tree leaked. How do I go about cleaning the lines out?
TIA
Jim
Old Jul 20, 2012 | 06:47 AM
Blue Jay's Avatar
Still wondering how to clean the ATF out of the vacume lines?
Old Jul 20, 2012 | 07:10 AM
Wonder no longer... Found using the search feature for 'clean+vacuum+lines' - 8th thread down the list:
Originally Posted by swartlkk
If you haven't already, I would flush all of the vacuum lines out with a mild degreaser like Simple Green followed up with blowing them out with compressed air, rinse, & repeat as necessary until they are all clean. If you don't get the fluid out of there, you could trash the new actuators again.
There are other, older responses that say very much the same thing as well, that I am sure of.
Old Jul 20, 2012 | 11:21 AM
Blue Jay's Avatar
Thanks I have searched for 2 days and did not find that. Must have had the wrong key words.
evomat
May 31, 2012 08:56 AM
dillon
19
Jan 16, 2011 07:36 PM
Gkolo
Oct 28, 2010 02:40 PM
Crestwood1001
May 26, 2009 08:13 PM
KA3AX
17
Nov 20, 2007 06:00 PM
