Clearing service engine soon light after intake install
Old Sep 6, 2011 | 09:41 PM
hypertek's Avatar
hypertek is on a distinguished road
Default Clearing service engine soon light after intake install
ANyone know how to do it? I installed a cold air intake a few months ago, and been driving with the service engine soon light that came on after installing it. Tried disconnecting the battery over night and the light would still come back.
Old Sep 6, 2011 | 09:44 PM
xgiovannix12's Avatar
You can clear them with a scan tool but disconnecting the battery would clear them also
if it comes on right away then there's something wrong I say scan the codes and see what its trying to tell you
Old Sep 6, 2011 | 09:59 PM
hypertek's Avatar
yeah that is a good idea. Has anyone else ran into this ? I dont see it documented very much.
Old Sep 6, 2011 | 10:01 PM
It may not have anything to do with your new intake setup or you may have done something wrong with the install. Diagnosis starts with the code so don't just clear it expecting it to go away.
A properly installed intake will not cause a code.
Old Sep 6, 2011 | 11:00 PM
bigcountry58's Avatar
bigcountry58 is on a distinguished road
Did you play with the MAF sensor at all? Touching the wires inside can cause issues, but you won't know whats wrong until you read the code. Did you put all of the sensors back in their proper spot? Did you reconnect all harnesses back up?
Old Sep 7, 2011 | 02:38 AM
DySfUnCtIoNaL's Avatar
DySfUnCtIoNaL is on a distinguished road
Take it to Auto Zone, they'll read the codes for you for free.
They aren't allowed to do it themselves but if you ask them to clear the codes, they'll show you what buttons to push to clear the code also.
Old Sep 8, 2011 | 12:27 AM
hypertek's Avatar
took a look at it today and realized I didnt see the hose on the back of the throttle body intake tube. , I missed it because I did not see it when the hose is off and it kinda plops down.
Old Sep 8, 2011 | 12:36 AM
did it fix the ses light ? =P
Old Sep 8, 2011 | 03:11 AM
hypertek's Avatar
I drove to oriellys to get a new front turn signal bulb since it burned out, and than drove to autozone to ask them to check for codes since the light was still on. Parked it and looked inside and saw alot of people in there. So then i said to hell with it and figured it should clear up. Started back up and drove home, it cleared a few blocks away.
Old Sep 8, 2011 | 08:01 AM
Leaving the fresh air make-up tube off the back of the throttle body 'hat' would definitely set a code. Whether that is the only code that is stored in the PCM, well you'll need to get the codes read to determine that. If that was the reason for the code, it should go away on its own.
McCabe29
Jan 28, 2011 10:40 AM
S10Blazer
Dec 3, 2006 11:59 AM
Bgray
Engine & Internal
Mar 20, 2006 11:42 AM
TwilightEpitaph
Aug 11, 2005 01:06 AM
gmyoyo
Engine & Internal
Mar 29, 2005 12:17 PM
