Climate control
Old Nov 26, 2019 | 12:25 PM
  #21
Mdz320's Avatar
Mdz320 is on a distinguished road
New relay.
Old Nov 26, 2019 | 12:32 PM
  #22
Mdz320's Avatar
How do I know which pin is upstream?
Old Nov 26, 2019 | 12:37 PM
  #23
GeorgeLG's Avatar
A word of caution. If the problem is under the U/H fuse block then disturbing it may lead to more problems if there is corrosion so I would not pull that up unless we verify the location through testing and then you have decided if you really want it fixed as original, can live without fan speed 4 or are willing to do a fused wiring jumper to leave that fuse block alone.
George
Old Nov 26, 2019 | 12:39 PM
  #24
GeorgeLG's Avatar
Pull the fuse and test both sockets for power. If you have power then while the fuse is out test the other pin to pin 87 of the relay for resistance/continuity.
George
Old Nov 26, 2019 | 12:47 PM
  #25
Mdz320's Avatar
This side reads 13.7 other, 0.
Old Nov 26, 2019 | 12:52 PM
  #26
Mdz320's Avatar
Nothing?
Old Nov 26, 2019 | 12:57 PM
  #27
GeorgeLG's Avatar
Test from the fuse pin that did not have power to pin 87 on the relay with the meter on 200 ohms and see what you get
George
Old Nov 26, 2019 | 01:05 PM
  #28
Mdz320's Avatar
George
Did I do it wrong?
Old Nov 26, 2019 | 01:13 PM
  #29
Mdz320's Avatar
40.5. what does this mean?
Old Nov 26, 2019 | 01:22 PM
  #30
GeorgeLG's Avatar
I cant tell if your in the hot side or the downstream fuse pin so I am verifying the pin that had no power and I would like to have you change the meter to 200 ohms instead of the diode/continuity setting as shown.
George
