'Clunking' noise felt/heard after replacing front shocks.
Old Mar 25, 2016 | 06:10 PM
jrm000kc's Avatar
jrm000kc is on a distinguished road
Default 'Clunking' noise felt/heard after replacing front shocks.
I'm at a loss for what could be causing this but I can 'feel' and hear something 'clunking' in particular my left foot on the floorboard. It's a 98 Blazer LT 4x4 and I didn't have this problem with the old, worn out shocks. I replaced them last weekend and noticed and felt the new noise. All I took loose was the ABS line that's in the way when installing/removing the shocks. I read 54 lbs of torque on the bolts but I simply tightened them a little past 'snug'. There doesn't seem to be any problem from the right side, it's all on the left and nothing feels or appears loose. Any suggestions? Thanks! New to the forum and glad I found it because I was able to repair my overhead console with the info I found. (I'm going to check the hood hinges just to be sure...but I'm doubtful because there wasn't any noise with the old shocks. They were an off-name brand that weighed nothing and were totally gone. I felt like I'd bounce off the road sometimes because here in Missouri our roads are getting pretty rough. Replaced them with Rancho RS5000's and am loving them so far.) Have a great weekend everyone! I'll update any findings.)
Old Mar 25, 2016 | 07:38 PM
newguy's Avatar
check your sway bar bushings
Old Mar 26, 2016 | 07:21 AM
Toocute350's Avatar
Toocute350 is on a distinguished road
Make sure you check your hood hinges.Open your hood,grab the driver side near the hinge try and shake it up and down/side to side.You will hear and see if you have any play,popping noise.Do the same thing for the passenger side.I had a popping sound everytime I rolled over any small pot holes or bumps.Another member told me to check my hinges for any play or popping sound.sure enough the popping sound I felt and heard on the driver side where the hood hinges.I had to buy a set of conical washers from G.M. Let me know if your hood hinges are popping/moving side to side.I do have part # for these washers if need be,just have to find it.
Old Mar 28, 2016 | 09:35 AM
jimspahr@msn.com's Avatar
Also recheck the shock bolts, top and bottom, and not just with the fingers. Use a socket and ratchet just as you did when you installed them. Sometimes when you jack the SUV up, it binds the suspension so that the new parts don't seat as they should. Then when you lower the vehicle back on the ground, the new part is loose even though it seemed tight when the suspension was up and compressed.
Also as Newguy said: check the swaybar bushings. That is the two bushings that hold the bar to the frame and the swaybar links on each end. The swaybar links are relatively inexpensive and often overlooked , even though they do go bad.
Old Apr 3, 2016 | 02:30 PM
jrm000kc's Avatar
Thanks for the help. I first checked the hood hinges and it looks like someone has already added washers to fix that problem. Pulled my tires and re-torqued the shock bolts. I found the problem-my sway bar linkages were pretty loose. Tightened them up and no more noise! Thanks again!
KM346
Jan 6, 2014 09:23 PM
ComputerNerdBD
13
Dec 2, 2011 07:12 PM
chris015
Nov 15, 2011 05:23 PM
Brock Samson
Jul 25, 2011 12:35 AM
grich
Apr 8, 2011 06:27 PM
