clunking when braking from pass front tire area
i just noticed it today, its been raining up here decently. i never slam on my brakes, or hardly every. its a decently loud clunking coming from the passenger tire area. i havent had a chance to take the tire off and look given its pouring out, the brake pad should be fine i checked it when i did my oil 3 months ago and they were about 60%.
any ideas of what i should check into first, also all grease points have been greased during the last oil change
thanks in advanced!
thanks in advanced!
Make sure the caliper is bolted up tight to begin with. Once you get it off take a good look at the pads and rotor. Look for uneven wear on the pads and/or a warped rotor. You may not be able to tell with the eye if the rotor is warped so a dial indicator could be very helpful.
i found the part number, 5470497. local dealer says this part is discontinued, but may still be able to order them. found them cheaper on ebay from a gm dealer, i should just replace both or just the broken one?
will have to pick up some sil-glyde, thank you! you just apply a light amount from what i was told right?
