cluster removal
it would be really helpful if we knew what year and kind of truck you are working on. You should put that info in your signature, you can edit it by clicking on "My Profile" at the top of the screen.
From reading your other post, you have a 98 Blazer.
To remove cluster
Drop knee bolster, two screws,
i believe one screw above the steering column and then your entire dash piece just unsnaps. When that is done, you can see the screws to remove the clustser. Just make sure that you mark where all your needles are at idle, little easier to get them back there.
To remove cluster
You wont need to mess with the needles at all. If you remove the clear plastic cover you removed the wrong screws. There will be 4 screws that hold the cluster into the dash, after you remove the dash trim, then the bulbs are on the back side. Korey.
It should, however, I believe that all 2nd gen Bravada's were floor shift with no shift indicator on the dash... This may or may not present a problem for you. If you are already floor shift, then you should have an indicator on the center console to tell you what gear you are in, but if not, get good at counting the clicks.
3kidblazer
Feb 1, 2009 11:22 PM
magtec
May 5, 2006 06:48 PM
