Clutch fan removal
Clutch fan removal
The manual says to "hold the water pump pulley and remove the nut attaching the fan to the water pump." Just exactly how are you supposed to do this? I cranked on the tensioner and the belt just kept on slipping while I tried to turn the nut. Any suggestions?
if you partially back out 2 of the water pump pulley bolts you should be able to hold with a screwdriver or even the flat bar from a belt tensioner tool
Those methods work great. If you're **** on using the tool, here it is: OEM/2 pcs. fan clutch wrench set (27018) | Fan Clutch Wrench | AutoZone.com_
The nut on the clutch is 36mm. An open end wrench works much better than the POS in the tool kit.
cheesequaker
04-25-2012 01:44 PM
MintyMadness
07-13-2011 12:37 AM
