code 304 (random misfire)
Old May 28, 2019 | 10:37 AM
kempo's Avatar
kempo is on a distinguished road
Default code 304 (random misfire)
This is driving me nuts! I''m getting code 304 at 2500 rpm inn a 97 s-10 4.3 vortec. I have sent this car to a shop who say they cannot recreate the misfire in the shop. I've replaced the plugs, wires, dist ,fuel spyder, maf sensor and at this point i'm stumped. l should add the motor has about 210000 miles on it. Has anyone had this issue? Also done extensive vacum checks.
Old May 28, 2019 | 02:20 PM
Mike.308's Avatar
Perform the fuel pressure test. It's in the sticky topic.A random misfire is also a symptom of a dying fuel pump.
If the spider is missing the fuel for injection You'll have a random misfire. Also, bear in mind, that 2500rpms on "Park" are not equal to the 2500rpms while Your ride is rolling (on "D"). The difference is within the engine load. The higher the load is, the bigger the fuel consumption is. That explains the problem with re-creating the misfire in a shop, if the transmission is on "park",
Old Jun 1, 2019 | 02:25 PM
kempo's Avatar
Mike thanks for the reply. Didn't mention, but also replaced fuel pump. Haven't done the pressure test, but will look at that. Again thanks for the reply. will comment on what I find as soon as I can. Out for the moment { Knee surgery}
Old Jun 1, 2019 | 02:53 PM
odat's Avatar
Have a speedy recovery - best of luck .....
Old Jun 1, 2019 | 06:47 PM
LesMyer's Avatar
Is this a repeatable code? Is SES light flashing?
Is this a felt misfire? If not, do a functional test on the misfire detection. Display misfire counters on a scanner and a pull plug wire on #4 (PO304) and then do same again on another cylinder that is not setting a code. Each case counter should increase rapidly on just that cylinder. If it doesn't, then misfire detection is malfunctioning and cannot be trusted.
FYI, excessive bearing clearance can cause false misfire codes. I have experienced this first hand. How's the oil pressure when engine is fully hot off the highway? Any lifters ticking?
Old Jun 1, 2019 | 11:31 PM
GeorgeLG's Avatar
To amplify Les’ point, a detected misfire is a detected momentary change In crankshaft velocity near the point where that cylinder should be firing. It’s not an actual electrical measurement.
George
Rleandro
Mar 8, 2018 04:50 PM
ethan_a97
Nov 2, 2014 08:53 PM
Spyderman310
Jun 13, 2014 10:13 PM
ardrummer081
Nov 1, 2013 12:12 AM
96blazer/02trailblazer
May 9, 2013 12:57 PM
