Code P0171 and P0174 set same time.
Old Nov 19, 2012 | 07:42 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
Default Code P0171 and P0174 set same time.
I have a 2005 Jimmy 2 door. Check engine light came on so used my cheapo scanner and codes P0171 and P0174 set same time. I was reading the forumns and was trying to figure out what to start first and lean towards.
1.) Both O2 sensors went bad same time
2.) Vacuum leak
3.) fuel pump problem
4.) fuel injector problem
Some background on recent repairs in the last year. New catylic converter gm replacement, all 3 O2 sensors ac delco, new delco plugs, new cap and rotor, new air filter.
Old Nov 27, 2012 | 03:25 PM
bump!!
Old Nov 27, 2012 | 06:42 PM
Check both sides of each fuse in the underhood fuse panel with the engine running: DVOM or a test light, doesn't matter. Specifically looking for a bad oxygen sensor fuse. Possibly one of the sensors shorted out. Then check fuel pressure and leakdown.
Old Nov 27, 2012 | 07:33 PM
Sounds good, I'll start with the fuse, and do a leakdown test the weekend.
Old Nov 30, 2012 | 05:23 PM
Major vacuum leak, where the breather tube enters the engine the vacuum line seperated, got it all fixed now.
Old Nov 30, 2012 | 05:35 PM
Nothing beats a good visual inspection
BlazinClint
Jan 28, 2016 12:54 PM
Bolbol
Mar 29, 2015 12:35 PM
crater
Nov 11, 2011 12:03 PM
stevie59
Jul 17, 2010 08:24 PM
hebelracing38
Jun 11, 2010 04:00 PM
