P0174 P0171 Engine code - terrible MPG
Old Mar 28, 2015 | 10:37 PM
Bolbol's Avatar
Bolbol is on a distinguished road
Default P0174 P0171 Engine code - terrible MPG
Got these engine codes but I'm trying to find ways to pin point the exact problem of what it is.
PCV valve is new, idle has no problem constantly at 600 rpm, but i have terrible mpg (8)
Spark plugs? wires? what could be the cause and how can i pinpoint the issue?
2001 Blazer LT 4wd
Old Mar 28, 2015 | 11:00 PM
No false Bravada's Avatar
No false Bravada is on a distinguished road
Those are trim codes, P0171 is fuel trim system bank 1 too lean P0174 is bank 2 fuel trim system too lean. What about the MAF? When those go bad or get dirty, they don't always set off the SES light or even set a pending code. The PCM is getting the wrong signal from the MAF, and it's either dumping way too much fuel or not enough. If that is indeed the problem.
Try cleaning the MAF and see if that helps
Old Mar 28, 2015 | 11:52 PM
Bolbol's Avatar
Last time I had a MAF problem I had idle issues too..
thing is before the light came on I also had a leaky pcv hose that I fixed but I am not sure if the computer picked it up in 5 miles of driving
Old Mar 29, 2015 | 12:09 AM
I had MAF problems with my Alero. Different vehicle,I know. But when the MAF was cleaned, the acceleration was much sharper and fuel economy went up by as much as 20% The Alero would also run rough at WOT when the MAF went hard altogether. When I unplugged it, it ran fine.
Same component, just different engine.
Old Mar 29, 2015 | 12:31 AM
Bolbol's Avatar
I see.
Well Ill try cleaning it again and run some fuel injector cleaners see what happens
Old Mar 29, 2015 | 01:08 AM
By the definition of the codes, the MAF makes sense. If the MAF is dirty or bad, the engine isn't using the correct amount of fuel, so the O2 sensors are picking up only a certain amount of fuel being burned, inconsistent with what the PCM knows it's supposed to be according to base values and sensor input.
Another possible culprit might be the fuel filter. When was that last changed? What of the intake air temp sensor? The engine uses fuel at a different rate, depending on temperature of the fuel itself and the temperature of the air.
Sorry if it seems like I'm grasping at straws here, I'm just thinking of the cheapest fixes first.
Old Mar 29, 2015 | 12:30 PM
Bolbol's Avatar
Fuel Filter was changed like 6k miles ago.. and the intake air temp sensor.... I have never touched it once..
And what would be considered an expensive fix? besides changing the injectors
Old Mar 29, 2015 | 12:35 PM
Low fuel pressure and or volume will cause those two DTC's to set simultaneously, and cause poor fuel mileage. https://blazerforum.com/forum/2nd-ge...eakdown-88305/ Post all 4 numbers and we can analyze them.
05BlackJimmy
Nov 30, 2012 05:35 PM
crater
Nov 11, 2011 12:03 PM
donfelix
Sep 20, 2010 08:18 PM
stevie59
Jul 17, 2010 08:24 PM
hebelracing38
Jun 11, 2010 04:00 PM
