Code P0301
Old Aug 17, 2011 | 08:24 PM
roy6912's Avatar
roy6912 is on a distinguished road
Default Code P0301
I have a '96 Blazer. It had a leaking intake manifold gasket so I replaced it. Put everything back together and now the truck is running rough and code P0301 pops up. Please help!!
Old Aug 17, 2011 | 08:26 PM
xgiovannix12's Avatar
this should help you out
https://blazerforum.com/forum/diagno...4-5-6-a-35153/
follow the steps and get back to us
Old Aug 17, 2011 | 08:30 PM
Since you removed the distributor during the intake manifold gasket, I would suspect a timing problem.
I would run through the EDI Engine Timing procedure to make sure that it is set properly. You may need to set the CMP Retard as well which requires a scan tool capable of displaying the CMP Retard.
Old Aug 17, 2011 | 09:51 PM
roy6912's Avatar
I Moved it about 50 feet and my buddy said it sounded like a machine gun.
stacbug77
Mar 18, 2012 12:59 PM
chevychallenged
Apr 5, 2011 07:20 AM
W2JGA
Mar 9, 2011 04:48 PM
greene
Feb 8, 2010 08:24 PM
bizutch
Jan 1, 2010 01:09 PM
