code p1345
Old Dec 24, 2013 | 02:04 PM
shayne391's Avatar
shayne391 is on a distinguished road
Default code p1345
1995 Blazer 4.3l 4X4. keeps giving code p1345. The distributor has never been removed. I dont think it is possible for the gear to be worn enough to set it off. I haven't checked the retard yet it does have a rough idle at times and does seem to vary at idle speeds, also at times seems to lose some power. my question is what else is a common cause for this code? my thoughts seem to take me in the direction of a faulty coil, cap, or rotor. Because it seems to be worse when its raining, especially the surging and rough idle. any thoughts?
Old Dec 24, 2013 | 02:09 PM
newguy's Avatar
Cap and rotor my guess if its during wet weather, could also be Spark plug wires. Start it at night and look for arcing on the wires. Also when its dry out start it and with a spray bottle spray with water and see if there`s a difference
Old Dec 24, 2013 | 02:44 PM
P1345 sets in memory when camshaft retard is off by ~27 degrees or more. That is the only thing that will cause the DTC to set. The causes, from most common to least common are:
1. The distributor gear is not meshed correctly with the camshaft gear, (off at least one tooth in either direction).
2. Worn distributor drive gear.
3. Worn distributor bushings.
4. Timing chain jumped at least one tooth.
Old Dec 24, 2013 | 05:12 PM
shayne391's Avatar
ordered a dist.gear. needs a tuneup anyway. ill try this first, since the code is intermittent. my original thought was a shorted rotor and/or cap causing a misfire.
Guess i'll see this weekend.
thanks.
Old Dec 24, 2013 | 07:29 PM
Before you remove the distributor: using a socket and ratchet, manually rotate the crankshaft clockwise so the index marks on the dampener, and the rotor segment, are lined up as follows:
DO NOT rotate the crankshaft while the distributor is removed. The distributor gear only goes on one way, (the small holes are not centered in the distributor shaft). Install the distributor so the rotor segment lines up with, or very close to, the "6" when the distributor is fully seated against the intake manifold.
If you replace the cap & rotor, make sure you install AC Delco parts, and put a dab of silicone dielectric grease on each terminal, inside and out, of the cap.
Old Dec 25, 2013 | 12:05 PM
shayne391's Avatar
Ok, thanks.
joethejman4us
Feb 16, 2010 09:25 AM
SuperBlazer
Feb 6, 2009 03:33 PM
96Ls4Dr
Jan 3, 2008 09:03 PM
4x4willywill
Dec 23, 2007 04:33 PM
Mr Blazer LT
Jan 17, 2007 11:25 PM
