Codes
Old Jun 7, 2013 | 09:36 PM
Rudex's Avatar
Rudex is on a distinguished road
Default Codes
Can some one help me out on these codes I got
And what you did to correct it
Please and thank you
P O 101
102
113
300
Old Jun 7, 2013 | 09:58 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
Do a Search, you'll be surprised what you find.
Old Jun 7, 2013 | 10:06 PM
rriddle3's Avatar
You should find all of them explained in this section:
Diagnostic Trouble Codes (DTCs)
Old Jun 21, 2013 | 10:25 PM
Rudex's Avatar
Hey I cleared all the codes and got it working
The fuel pump had a broken nozzle
Which looked like someone had to put j b weld n tape on it
The previous owner said he had just replaced the fuel pump
I changed the filter and engine oil all to be safe
But after I let it run for awhile
And I decided to take it for test drive and I noticed it not accelerating at all
I press down the pedal almost to the floor and no acceleration at all and cuts out
I looking for some reasons in post here.
I think it's the converter
If you had this problem please show me a solution of a post
Or any advice would be greatly appreciated
Old Jun 22, 2013 | 06:44 AM
rexazz2's Avatar
If you can get some one to rev it in park while you stand at the tailpipe it sounds like you got a couple extra mufflers when the cat. plugs up
Old Jun 23, 2013 | 05:35 PM
Rudex's Avatar
White smoke in exhaust and brown yellowish oil
Does this mean a gasket problem??
Which would be most work replace the head gasket
Or replace the whole engine??
Old Jun 27, 2013 | 09:11 PM
baracuda645's Avatar
baracuda645 is on a distinguished road
White smoke and yellowish oil? is it creamy like mayo? that's a bad head gasket.
I found it more cost effective to do the head gaskets myself, but I've done them before. Removing the hood will give you all the room you need.
Old Jun 28, 2013 | 09:05 AM
chris015's Avatar
if the oil looks like coffee with coffee creamer in it,you have a bad headgasket/cracked head/or blown intake manifold gasket.
Kilo
Jul 27, 2013 06:57 AM
abadinalbany
Apr 16, 2011 11:31 AM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
