Codes just keep coming
So I had a misfire on 2 cylinders and the O2 sensors were trash. Changed the plugs,wires, cap, rotor, ignition coil and all 3 o2 sensors. Now I have a misfire on cylinder 6 and an evap code. Am I wrong in thinking my cat is toast? No smell, but bogs down a bit when I first get moving and runs a little rough. I want to get it mechanically sound before I start building it up. Only has 131k miles on it and a 2000 2 door 4x4.
How did the plugs look?
Especially in the cylinders that were misfiring?
Also did you use AC Delco for Cap/Rotor replacement?
These engines are picky about ignition parts.
I had a off brand Dist cap crossfiring underneath years ago.
Caused all kinds of problems, ACDELCO all the way
Do a fuel pressure bleed down test
polarbear18w
13
09-23-2011 01:27 PM
