Cold air intake problem.
Old Aug 13, 2009 | 06:31 PM
blacer2000's Avatar
blacer2000 is on a distinguished road
Default Cold air intake problem.
I just put in a new cold air intake on my blazer and when I started it ran pretty crappy. I plugged in everything and there are no leaks. What's going on??????Did I mess up a sensor or something when I did it?Thanks for the help.
Old Aug 13, 2009 | 07:03 PM
rriddle3's Avatar
We can guess that you have a 2000 Blazer from your user name, but we don't know what kind of CAI you installed and nobody watched you install it, so it's a little difficult to diagnose the problem. It's a pretty safe bet to say that something did not get installed correctly, though, since a CAI alone should not make the engine run poorly.
Old Aug 13, 2009 | 07:08 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Snap a picture or two, also; did you install a heat shield? and is the intake a name brand or a knock off? if its a junk filter it could be causing trouble. get us some pics so we can exclude the obvious!
Old Aug 14, 2009 | 10:04 AM
blacer2000's Avatar
My setup looks exactly like the one shown on the picture. I unhooked the battery terminals for a little while and took it for a test drive( a couple trips of like 15 miles) and is not running bad after all. But this morning when I was driving to work the check engine light came on. Not sure why, anyone has any ideas? Are you supposed to let the computer know of the changes you have made or something???? I haven't scanned the code yet but as soon as I do I will post the results.
Old Aug 14, 2009 | 10:27 AM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Did you put the mass air flow sensor in backwards??? theres arrows on it to make sure ya have it the correct way!!
Old Aug 14, 2009 | 10:29 AM
blacer2000's Avatar
I checked the mass air flow sensor and I think put it the right way, with the arrow pointing towards the engine. Right?
Old Aug 14, 2009 | 11:00 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
If you took off the plastic intake that attaches to the throttle plate, did you reattach the breather line that goes from it to the passenger side valve cover?
Old Aug 14, 2009 | 11:12 AM
blacer2000's Avatar
Hahaha, I don't know if that is the reason but I know for a fact that I did not put that hose back. I remember playing with the intake a long time to get the fittings to fit nicely and completely forgot about it. That should probably fix it. Thanks a lot. I will let you know how it goes.
Old Aug 14, 2009 | 03:06 PM
also, your going to want to replace the cheapo ebay filter ASAP! get a K&N or spectre or somethin, those ebay ones are no good!
ravenhurst
15
Apr 26, 2009 07:53 AM
dimmuborgir6nik6
Oct 2, 2008 06:51 AM
BlaZeR FXB1581
Headers, Intake, & Exhaust
Jan 26, 2006 08:11 PM
il67bp
Aug 16, 2005 01:33 PM
Long Live #3
Feb 15, 2005 11:41 PM
