Compatibility questions
Old May 24, 2010 | 11:38 AM
Fusefinder's Avatar
Fusefinder is on a distinguished road
Default Compatibility questions
First off, if this is in the wrong section please forgive the newbie and redirect me to the correct location.
I have a 1998 S10 Blazer and a 2002 Blazer, What years are parts compatible, mechanical and interior. Both 4dr 4wd 4.3L Vortec.
I have also within the last week attained a 1998 S10 PU Ext cab 2wd 2.2L
The interior looks very similar, what years are compatible, front seat forward interior. I am also looking to increase tire/ wheel size from 215/75/R15 on the S10 as they are heavily worn.
Last edited by Fusefinder; May 24, 2010 at 04:55 PM. Reason: Fat fingered tire size
Old May 24, 2010 | 05:08 PM
step66's Avatar
Hey. The two 98's are almost completely compatible,you will,however, find many little things that aren't! As for the two Blazers,dramatic changes took place in those 4 years:fuel tanks/pumps,ABS controls,and as you may have noted :interior appointments.
When I was doing a swap over from a 96 to 97 Jimmy,I found such minute changes,I figured:why did GM bother and not address the severe engineering flaws?
Also fairly sure that at least 235/70/15's will fit the stock rim and not pose clearance issues on a 2wd but going to a 70 series may affect speedometer readings slightly.
Old May 24, 2010 | 09:01 PM
kickme005's Avatar
Banned
kickme005 is on a distinguished road
fix up the 2002 its a better Blazer
Old May 24, 2010 | 09:05 PM
zedartwo's Avatar
Not necessarily! It could be the worst of the bunch. Yea the 2002 is the newest but the 98's are only 4 years older. Depends on the overall shape!
Old May 25, 2010 | 02:27 PM
kickme005's Avatar
Banned
if it was me i'd go with the 2002 cuz it worth more and maybe it has better features but if there are major things wrong then i go with the 98 Blazer. What wrong with the 3 chevy? you sould pput pic on here
Dan39
Jan 16, 2009 08:52 PM
stevelknievel
May 18, 2008 11:15 AM
ack
Feb 11, 2008 06:15 PM
jimmychick07
Feb 11, 2008 04:45 PM
EMTBlazer
Dec 3, 2006 07:13 PM
