starter compatibility
Old May 17, 2008 | 01:28 PM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
Default starter compatibility
my 97 jimmy's starter has been throwing fits lately and i have a good starter off my 92 FS that has the 4.3 TBI motor,
will the starters interchange?
Old May 18, 2008 | 10:10 AM
94_SBlazer's Avatar
94_SBlazer is an unknown quantity at this point
Default RE: starter compatibility
i want to say that it will but im not a 100 % sure so maybe somebody else on here will be able to back me up
Old May 18, 2008 | 11:15 AM
Hanr3's Avatar
GM uses a couple of varieties of starters, some larger then others, and the mounting bolt locations vary, or the type of tranny varies.
Compare the two side by side.
Look at teh overall size.
Look at the mounting holes, some are straight across and some are diagonal, some starters will fit both applications.
Then look at the location of the small hump on the side of the starter.
Are both vehicles auto trannies or both manual trannies. The flywheel/flexplate teeth count is different between the two. A auto tranny starter wont work in a manual flywheel and vice versa.
jdmmario
Oct 25, 2014 06:25 PM
Dan39
Jan 16, 2009 08:52 PM
ack
Feb 11, 2008 06:15 PM
jimmychick07
Feb 11, 2008 04:45 PM
EMTBlazer
Dec 3, 2006 07:13 PM
