Constant Belt Squeal
Old Dec 7, 2018 | 07:32 AM
01bravada's Avatar
01bravada is on a distinguished road
Default Constant Belt Squeal
I have an 01 Bravada Platinum that I just picked up as a daily driver. When I got it I noticed a belt squeal. Well I changed the belt, tensioner assembly, and idler pulley. The squeal is still there and doesnt get higher when the rpms go up. I figure before I aim the parts cannon at it I would check and see if anyone else has the same issue. Thanks in advance for any help.
Old Dec 7, 2018 | 12:24 PM
Strangerock's Avatar
Strangerock is on a distinguished road
A friens had that on a 05 jimmy and it went away when he bought the Gator back belt and went away from the GM belt......GM even replaced their belt 2 times on warranty.
Old Dec 7, 2018 | 03:02 PM
Zenith's Avatar
Zenith is on a distinguished road
"The squeal is still there and doesnt get higher when the rpms go up."
That's strange it doesn't increase with RPM's.
I would do a process of elimination.
Get a can of spray silicon and hit the inside of the Alternator pulley, if that doesn't help, spray a little behind the PS pulley, etc until you find the culprit or at least eliminate what it is not.
Old Dec 7, 2018 | 05:05 PM
sabre420's Avatar
sabre420 is on a distinguished road
I would take the belt off and run the engine for like 30 seconds and see if the noise is gone. At least then you'll know for sure it's a problem with the belt or something belt driven. Like the other guy said it's weird it doesn't increase with RPM. Running it like that for 30 seconds or a minute or so won't hurt anything.
Old Dec 9, 2018 | 08:05 PM
RQuickDraw's Avatar
RQuickDraw is on a distinguished road
+1 for the Gator belt.
Old Dec 10, 2018 | 11:18 AM
mr.vls's Avatar
Goodyear Gatorback is now Continental Elite.
I also a firm believer. My belt squeaked ever since I bought my 89 S15 Jimmy and I tried everything before I read about the Gatorback Belt. It worked.
Check on Amazon for Continental Elite Belt.
bgonzo
14
Mar 30, 2013 12:13 PM
ChevySkeptic
Apr 15, 2012 06:36 PM
racsan
Apr 24, 2011 07:38 AM
mkm1387
Sep 26, 2007 09:52 PM
BrokenBlazr
Nov 4, 2006 10:00 AM
