Constant turn signal click PLEASE HELP
Old Mar 29, 2008 | 04:17 PM
boomb1's Avatar
boomb1 is an unknown quantity at this point
Default Constant turn signal click PLEASE HELP
The sound of the turn signal can be heard even though the signal itself is off. It sounds as if it's coming from the glove box area, but i have no clue. The only times it stops is when the brake is pressed or when the fuse is pulled. When you put the fuse back in and turn the car on, it immediately starts up. Is there a wiring problem, or something else? Please help as this is VERY annoying.
Old Mar 29, 2008 | 05:00 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: Constant turn signal click PLEASE HELP
what happens to it of you use the 4ways ??? have you tried that?
Old Mar 29, 2008 | 05:06 PM
blazinloud's Avatar
Mine does the same same thing. I belive its a faulty mulitfunction switch. if you search for that you can find other posts about it.
Old Mar 29, 2008 | 05:20 PM
boomb1's Avatar
Trying the ways has the same effect as the brakelight. Cuts it out, but the moment you switch back, it's there again.
Old Mar 29, 2008 | 07:04 PM
What is it that you are working on here? Need atleast year to properly diagnose. It could be the difference between just replacing the Hazard switch and replacing the full multifunction switch.
This topic has been discussed many times before in the past. Try running a search for a post entitled "Clicking in the dash" or something to that affect.
Old Mar 29, 2008 | 09:37 PM
NVANZEE's Avatar
I had the same thing. I replaced the relayt and now it is fine. It is located behind the glove box. To fold the door all the way down there is a small metal loop in the top left corner that you have to lift up on. The relay is down in the bottom right corner. Hope this helps.
Old Mar 30, 2008 | 12:42 PM
boomb1's Avatar
Appreciate all the help, everyone! I'll give it a go and see what I can come up with.
White Locust
Feb 13, 2014 10:58 AM
clbychil
Apr 12, 2011 11:20 PM
davedidit
Dec 12, 2010 06:54 PM
nnnon632
Dec 31, 2009 04:40 PM
[[B3k@h]]
Jan 1, 2008 12:32 PM
