control arm bushing question
Old Nov 14, 2014 | 11:25 AM
er0ck273's Avatar
er0ck273 is on a distinguished road
Default control arm bushing question
I have had squeaking every time i brake in the right front passenger side...took it to 2 places....both saying they beloeve cause of squeaking is my rotting control arm bushings....both quoted me 200 to 500...thats either just bushing of all new control arm...my ball joints werw just replaced so money is tight for something thats not a necessity to replace now ..
Would this really be the reason i get squeaking only when braking? Also is there anything i can spray on the bushings or area to temporarily kill the squeak?
Old Nov 14, 2014 | 11:38 AM
TZFBird's Avatar
TZFBird is on a distinguished road
Is is a short squeek or does it continue until you let off the brakes or the vehicle stops?
If it is more than a short chirp it would have to be brakes. I suppose there is the possibility of it being the bushings but they would have to be pretty bad to have metal on metal so that it would squeek.
Spraying them with some kind of lubricant(WD-40, etc) would let you rule them out if the squeeking continues.
They are not a lubricated piece and I do not know the compatability of the rubber and certain oils. You'll have to run your own risk with what you use.
Old Nov 14, 2014 | 02:47 PM
er0ck273's Avatar
it continues until i let off the brakes. my friend seems to think my pads are loose and a shim kit may help but theyre hard to find he said
hes basing it off my description he hasnt looked at anything yet
Old Nov 14, 2014 | 02:48 PM
er0ck273's Avatar
i dont hear it driving or when i brake in reverse....only forward braking
hurleyii
Mar 29, 2014 03:49 PM
kancop
Mar 3, 2014 06:16 PM
05BlackJimmy
Mar 26, 2012 09:05 PM
bansheedave
Mar 19, 2012 05:11 AM
Marcin
Nov 11, 2006 10:03 PM
